Balance Beads - Wooden Wheels
bdtutton
First Name: Bryan
Last Name: Tutton
* REQUIRED* Type and Year of Model Ts owned: 1914 Model T
Post by bdtutton » Tue Jul 20, 2021 1:41 pm
I have a 1914 Touring with clincher wooden wheels that I am almost finished restoring. It is sitting on jacks with all 4 wheels in the air and the wheels are nice and round and straight, but seem out of balance. Besides being wooden wheels I am using the heavy brass valve stems and brass dust covers so I would expect them to be out of balance. I have new tires, flaps, tubes and have even replaced the bearings and seals because I would like to run the car 35-40MPH for short bursts when needed. How much of a wheel balance problem do you think I will have? I have read that balance beads can balance any Model T wheel.
What the general opinion about balance beads in wooden clincher tires with brass stems and brass dust covers?
Pep C Strebeck
First Name: Joseph
Last Name: M
Re: Balance Beads - Wooden Wheels
Post by Pep C Strebeck » Tue Jul 20, 2021 3:10 pm
I have Dyna-Beads in all 4 tires and there is a noticeable difference.
Post by Scott_Conger » Tue Jul 20, 2021 6:37 pm
Dyna-Beads are one of the few products in life that usually deliver more than expected. They are a very good enhancement for a typically unbalanced T wheel.
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Tue Jul 20, 2021 6:53 pm
I have them in my 15 touring car for the last 4-5 years and they real have improve drive ability.
Last Name: Juhl
Post by Oldav8tor » Tue Jul 20, 2021 8:11 pm
I have 6 oz of Counteract balancing beads in each of my tires. I notice absolutely zero out-of-balance indications while driving - across all speed ranges. The fun part is introducing the beads into the tubes. I attached a plastic hose to a condiment bottle and slip the other end over the valve stem (held in place by a small hose clamp). It requires patience..... if you have trouble getting the beads to flow smoothly I've found that vibrating the valve stem with an electric engraving tool will help.
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Tue Jul 20, 2021 8:57 pm
I've had balancing beads for about the last 10 years. I only noticed their effect at high speed. Getting them into the tube requires patience, not to try and pour them in too quickly or the tyre valve blocks up.
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Tue Jul 20, 2021 9:28 pm
A recurring theme I agree with. Definitely bring your patience when attempting to put them in. Instead of an engraving tool as mentioned above, I used a Dremel tool to provide the vibration to help them down the tube and into the stem.
