How important is it to use the heat pipe that was made for the Vaporizer carb.?
and how rare are they to find
Bob
Vaporizer Carb. question
Re: Vaporizer Carb. question
What heat pipe? I do have a small sheet metal shroud that fits over the intake. It sort of directs the intake air from side draft(horizontal) to up from the bottom(vertical).
I understand it was used on earliest production & eliminated for being unnecessary.
FATMAN
Topic author - Posts: 1697
- First Name: ROBERT
- Last Name: BERGSTADT
Thank you, I know they sell for a lot on e bay, Bob
I got that backwards. The carb opening is pointed down. This tin piece redirects air from a horizontal direction.speedytinc wrote: ↑Wed Jul 21, 2021 11:39 amWhat heat pipe? I do have a small sheet metal shroud that fits over the intake. It sort of directs the intake air from side draft(horizontal) to up from the bottom(vertical).
