1926 Engine Model T
4banger1988
First Name: Patrick
Last Name: Ortlauf
* REQUIRED* Type and Year of Model Ts owned: 1926 Ford Model T Two Door Sedan
1926 Engine Model T
Post by 4banger1988 » Thu Jul 29, 2021 5:50 pm
Hi
I currently have my motor on the stand!
i will overhaul the gearbox.
the engine was running, but i would like to check the main and connecting rod bearings with plastigage!
what kind of clearance is ok?
and which torques do you use for main and connecting rod bearings? greetz patrick from germany
Last Name: van Ekeren
Re: 1926 Engine Model T
Post by Kerry » Thu Jul 29, 2021 6:44 pm
Clearance needs to be .0015", .002" at the very most. As for tension, I still use the original method. Mains as tight as you can swing on them with long socket bar and rods tight enough so not to strip the threads.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Thu Jul 29, 2021 7:00 pm
As stated above 0.0015-0.002 is about it. 70ft/lb on the mains and 35ft/lb on the rods.
Brad
4banger1988
First Name: Patrick
Last Name: Ortlauf
Post by 4banger1988 » Fri Jul 30, 2021 3:14 am
Thank's
Greetz patrick
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Fri Jul 30, 2021 10:25 am
As in Henry's days Torque specs were not a common thing, some of us are in the dark about how much to tighten, say the head bolts.
As a general guideline you can use the specs given in this chart, BUT... use with care on our old machines and old fasteners.
At least it gives you a ballpark value, but proceed with care, inspect threads and holes well, be sure to clean out debris and lightly coat fasteners with oil or another appropriate lubricant.
Then start with tightening with half or two thirds the value specified and carefully work your way up.
Oh and allway, ALLWAYS try the torque wrench first in the vice, you would not be the first to dicover it is not 'clicking' while you strip the threads (don't ask)
you may print this and hang it on the shop wall
Leo van Stirum, Netherlands
