'26-'27 Brake cam dimensions
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Jan 02, 2020 1:39 pm
I need to replace my brake cam bushings and need to decide if I need to replace the cams too. Does anyone know what the thickness of the cam head should be? I can measure the shafts for wear but I don't have a reference for cam thickness.
Inkedbrake cam_LI.gif (112.31 KiB) Viewed 2608 times
Scott C.
Last Name: Clements
Re: '26-'27 Brake cam dimensions
Post by Scott C. » Thu Jan 02, 2020 7:20 pm
I measured a set of new ones at .740" and a nice original one at .752".
ModelTGal
First Name: Jennifer
Last Name: Pierce
Post by ModelTGal » Sun Aug 08, 2021 12:17 pm
Anyone know if the new pinned brake cams are providing good service? I hear the earlier replacements were splined and didn’t do well…
Jennifer
Last Name: Gregush
Post by Mark Gregush » Sun Aug 08, 2021 2:00 pm
Jennifer
Don't know yet, ask in a few years! :) Just got a set to install on customer's car. They will just be operating as parking brakes. I was glad to see they were pined, was going to do that if not.
Post by Allan » Sun Aug 08, 2021 8:29 pm
In light of the problems with the two piece repops, I would be chucking the shaft in the lathe, machining a substantial grove around the shaft and cam interface, and adding a substantial weld to further unite the two components.
