Carburetor Identification
Devon
First Name: Devon
Last Name: Hall
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
Post by Devon » Fri Aug 13, 2021 5:20 pm
Hello all! I recently acquired my first Model T, a beautiful 1926 Roadster. I don't recognize the carburetor or know anything about it. Does anyone recognize what it might be? Thanks!
Re: Carburetor Identification
Post by RajoRacer » Fri Aug 13, 2021 5:25 pm
Pretty sure it's off a Kohler or similar lawn tractor engine.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Fri Aug 13, 2021 5:29 pm
Definitely a much more modern carburetor than was available in “the day”....
But I just have to ask, how’s it run ? :)
Last Name: Strange
Post by CudaMan » Fri Aug 13, 2021 6:04 pm
Post by Scott_Conger » Fri Aug 13, 2021 6:25 pm
Keep looking and you're likely to find a fuel pump, too.
welcome to the affliction!
Devon
First Name: Devon
Last Name: Hall
Post by Devon » Fri Aug 13, 2021 7:39 pm
Well that is certainly not the answer I was expecting. Thanks everyone for the info, I'll certainly be switching it out!
Post by RajoRacer » Fri Aug 13, 2021 7:39 pm
No fuel pump needed for the "Improved" model with cowl tank.
Post by Scott_Conger » Fri Aug 13, 2021 8:12 pm
Steve...even with a Walbro?
I've only seen a couple of them and I know they needed the pump...neither was an improved car, but I'd expect that the float valve is so small that it wouldn't likely perform well without one even with the tank mounted higher. With so little experience with them, I'm quite possibly wrong, but I've never heard or read of one performing on a T without help.
Post by RajoRacer » Fri Aug 13, 2021 8:17 pm
That's probable - never had one to play with.
