Model T Generator 12 V Cut Out, Voltage Regulator
MbStew5755!
Topic author - Posts: 19
- Last Name: Stewart
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Ford Truck
[image] Do anyone know where I can buy a 12 Volt Cut Out / Voltage Regulator? Mack's , Lang's and Snyder's don't seem to have one in stock. I an going to use a 12 Volt Battery on my 1924 Model TT Truck. Have the light bulbs and battery just need the cut out. Thanks
Re: Model T Generator 12 V Cut Out, Voltage Regulator
Any diode cutout will work. there is a replacement unit on ebay for under $14MbStew5755! wrote: ↑Sat Aug 21, 2021 3:26 pm[image] Do anyone know where I can buy a 12 Volt Cut Out / Voltage Regulator? Mack's , Lang's and Snyder's don't seem to have one in stock. I an going to use a 12 Volt Battery on my 1924 Model TT Truck. Have the light bulbs and battery just need the cut out. Thanks
"New Generator Cutout Electronic Universal 6v, 12v, 24v, Volt DELCO D1702, D1703" Here is a paste of it.
Remember to 1/2 or better the generator output. 4 amps is plenty.
MbStew5755!
Thanks. I thought I would have to replace the original 6 V Cut out on the generator with a 12 V one.
An original style mechanical type - yes.MbStew5755! wrote: ↑Sat Aug 21, 2021 3:42 pmThanks. I thought I would have to replace the original 6 V Cut out on the generator with a 12 V one.
Mark
just so you know, a cut-out is a cut out. A voltage regulator is a voltage regulator. The VR was a very popular product as it detected when the battery needed a charge and when it did not, thus keeping the battery from abuse at the speeds we drive.
A diode works like a cut-out but like a cut-out is not smart enough to quit pouring the coal to the battery. If the VR ever becomes available again, it is a wise investment.
