Question regarding engine parts compatibility
Topic author - Posts: 86
- First Name: Jack
- Last Name: Tarlinton
- * REQUIRED* Type and Year of Model Ts owned: 1927 Cut off
Hi all,
I'm a newby in Australia so while I've had my head in deep research for 6 months I am compelled to ask what some may deem as stupid questions...
I bought a 26 touring cutoff as a pile of completely disassembled parts. Probably 4-5 different cars in the body alone.
The assembly of the chassis and body is progressing well, and I am now starting to plan the drivetrain build for next year.
The pile of Model T stuff came with a 4 dip pan, plus a seperate, 1923 engine with no pan (recently running) and no auxiliaries. I
There is no transmission.
The fellow I bought the car from says he has found the RHD hogshead.
My questions are:
1: Can I use the 23 engine on the 4 dip pan?
2: If the hogshead turns out to be a 26/27 version, can I use it on the earlier block?
Thanks everyone
Jack
My questions are:
Thanks everyone
Jack
- Last Name: van Ekeren
Re: Question regarding engine parts compatibility
No 1, yes.
No 2, only if you use the 26/7 wide brake drum transmission.
- First Name: Jack
- Last Name: Guitar
- Board Member Since: 2012
Jack,
If you can find a 26-27 engine that would be a better option than the 23.
Whereabouts in Sydney are you?
John
John
- First Name: Jack
Hi John,John E. Guitar wrote: ↑Thu Aug 26, 2021 11:58 pmJack,
John
I'm in the Sutherland area.
- First Name: Henry
- Last Name: Lee
You have to grind off the rear ears on a 26/27 hogs head that were meant to attach up high on the rear of the block. Use the re-enforcement plates from the bottom of the oil pan that join the hogs head and block together. Been doing it for about 40 years with no ill effects!
This mod is for when using a large drum transmission with an early block.
- Last Name: Guitar
Have you considered joining the NSW Model T Club? There might be someone in the club who has a 26/27 engine they could sell you.
I'm in the Parramatta area. I've got a 26 Tourer and a 24 Tudor you're welcome to have look at once the lockdown eases up.
My 1925 with 4 dip pan came with those. Don't know if they were added or factory.Henry K. Lee wrote: ↑Fri Aug 27, 2021 1:05 pmYou have to grind off the rear ears on a 26/27 hogs head that were meant to attach up high on the rear of the block. Use the re-enforcement plates from the bottom of the oil pan that join the hogs head and block together. Been doing it for about 40 years with no ill effects!
- First Name: Jack
Hi John,John E. Guitar wrote: ↑Fri Aug 27, 2021 5:10 pmHave you considered joining the NSW Model T Club? There might be someone in the club who has a 26/27 engine they could sell you.
Yes, absolutely considered joining the club - just waiting for this recent lockdown to finish before I send off my application. I am already in contact with several members who've been helping me find parts.
And thank you for your offer of a visit, I would love to come and see your cars. Let's stay in contact!
