Tool found in Model T parts
Unprr
Topic author - Posts: 294
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
I found this tool, with Model T parts, I purchased last week.
The name on the side is very faint but it appears to be ( New Britain VL-200 ).
Any clue, what it is?
George Schmidt
Elkhorn, Nebraska
George Schmidt
Elkhorn, Nebraska
Re: Tool found in Model T parts
That's a valve spring compressor. It may be designed for a Ford flathead V8. It could probably be used for others.
Not intended for a T, nor needed for one. However, will work very well with a T (I would imagine?). I have one very similar to that, used it once on a modern V8 (can't now remember why I needed to compress an overhead valve on an assemble engine?). Used upside down and/or backwards it was tricky, but got the job done?
I have others I use on the Ts and they seem to be easy enough. My one like that just hangs on a wall in case somebody (me or anyone I know) needs it.
Mine is one of the many tools my dad had, and he wasn't sure what it was for.
Don D
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
Stanley Tool was based out of New Britian, CT. I'm not sure if this helps but my 2 cents!!!
Unprr
Thanks to all who replied. It will make a nice wall art. LOL.
George
George
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Though slow that would make one hell of a cherry pitting device…
PS-Have a similar one on my wall.
tmodeldriver
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
That's a valve spring compressor for over-head valve engines.
The spring fork shown is made for small diameter springs typically found on older flathead engines. OHV engines require larger (overall) springs to control their larger valve train mass. The tool may have come with several sets of spring forks to accomodate Fords, Chevrolets, and Buicks. It will work with many OHV heads, and it remains a useful tool.
- First Name: craig
- Last Name: leach
Yep thats a valve sring compesser. They make them in all sizes from Briggs & Straton to big truck. I prefer them to most made for model T's they give you more room to install the pin in the valve stem. You can add washers to the yoke if its to small for what you are working on (up to a point)
It's allways great to get bonus tools.
