HOOD LATCH SPRINGS
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
HOOD LATCH SPRINGS
Post by Professor Fate » Mon Sep 13, 2021 2:06 pm
On my '26 the rear hood latch's went on slick. The fronts are an issue. The springs that came with the kit are too long to even fit/compress between the c shaped frame rail.
Am I to cut a few rounds of the spring off?
________________
**FATE**
Re: HOOD LATCH SPRINGS
Post by TXGOAT2 » Mon Sep 13, 2021 2:21 pm
Are all 4 springs the same length?
Professor Fate
Last Name: S
Post by Professor Fate » Mon Sep 13, 2021 2:39 pm
Same length x 4
________________
**FATE**
Post by Scott_Conger » Mon Sep 13, 2021 2:49 pm
FYI
a) there are wood blocks which belong between the sheet metal hood strip and the frame rail
b) the washers supplied in your kit are too large and should be JUST smaller in diameter than the holes in the frame
c) the whole mess should be pre-assembled on the bench and then lowered onto the car...no fiddling with cotters in a confined space inside the frame rail or under the splash apron
Professor Fate
Last Name: S
Post by Professor Fate » Mon Sep 13, 2021 4:32 pm
I have the wood blocks.
Don't have smaller washers.
And there's no way the assembled headache will go in thru the frame from above without substantial drilling. Not drilling. Gotta be another way. Like cutting the spring length down.
________________
**FATE**
Post by Mark Gregush » Mon Sep 13, 2021 4:53 pm
Buy smaller washers or grind the OD down to fit through the holes.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Mon Sep 13, 2021 4:54 pm
Make the washers you have smaller. File or grinding wheel
1926 Tudor
Post by Scott_Conger » Mon Sep 13, 2021 5:02 pm
well, heck, I wouldn't drill out my frame to accomodate wrong, $.10 washers either!
There's noting wrong with putting things together correctly, and several respondents have explained what needs to be done. It seems like you're simply determined to cut the spring, so go ahead do that and let everyone know how that works out for you. It's not like the wheels are going to fall off if you do...
You asked what you needed to do (cut off the spring?), and now you know (which is not cut off the spring). Not sure why you'd ask the question and then not take easily executed advice... :?
Post by Norman Kling » Mon Sep 13, 2021 6:18 pm
I just got through installing one on a 20. I used a large washer and it fit under the frame. I had trouble getting the spring compressed to put through the cotter pin. I put the handle with the spring on it in a vise and used a thin piece of stainless wire through through the inside of the spring. The handle shaft fit through the spring with that wire inside. I compressed the spring in the vise and twisted the wire to hold the spring and then went back to the car and installed the rod through the sill, frame, washer and spring. I was able to get the cotter pin in place then I cut the wire. It works.
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Post by Nunsio1 » Mon Sep 13, 2021 7:51 pm
Had the same problem.. I used roll pins instead of cotter pins, smaller washers and enlarged holes in the frame - worked better. Also cut 2 loops off each spring.. still have plenty of tension to hold your hood during normal operation.. but I remove hood when on my open trailer at highway speed.
John
Oscoda Michigan
Professor Fate
Last Name: S
Post by Professor Fate » Mon Sep 13, 2021 8:47 pm
Last edited by Professor Fate on Mon Sep 13, 2021 9:40 pm, edited 1 time in total.
________________
**FATE**
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Sep 13, 2021 8:50 pm
A local parts store should have metric 6 mm ID with a smaller OD than yours. Normally fixes that problem.
Hank
Professor Fate
Last Name: S
Post by Professor Fate » Mon Sep 13, 2021 9:04 pm
Thank you Hank.
I gotta check my stash because I just remembered I have at least 2 old latches with springs. Maybe they're shorter. We'll see tomorrow.
________________
**FATE**
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Mon Sep 13, 2021 10:26 pm
Get washers that the ID fits the latch "shaft".
Put on a spring and one or more of the washers.
hold the whole mess against the wheel on your bench grinder until the OD of the washers is the same as the OD of the spring.
Post by Allan » Tue Sep 14, 2021 12:23 am
The whole fitting procedure/problem largely goes away if you use lighter weight springs than those ridiculously stiff repops. There is no need for them to be so tough, especially when they are pulling on an aluminium hood on an early car.
Others do it differently.
Post by speedytinc » Wed Sep 15, 2021 6:24 pm
Have this problem disassembling customer cars. The washers need be no larger than the spring diameter. I have used flat washers designed for counter bored allen bolts. They matched original washer size close. Standard sae are way too large.
Professor Fate
Last Name: S
Post by Professor Fate » Fri Sep 17, 2021 9:37 pm
Visual comparison.
Measured the old spring is thinner and shorter than the repop.
________________
**FATE**
