Drag link end caps?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Drag link end caps?
Post by ivaldes1 » Mon Sep 13, 2021 1:02 pm
For drag link end caps I see three different possibilities:
. APCO for worn ends from Lang's https://www.modeltford.com/item/2728APCO.aspx
. Cap shown in the picture that I received from Dave Huson.
. Grease cap shown in the picture that came with my Touring.
Are all of the above ok or is there something in particular I should be doing?
Last Name: House
Re: Drag link end caps?
Post by George House » Mon Sep 13, 2021 1:59 pm
Of course they’re all ‘OK’ and dependant on the shape of the balls on both ends. If they’re slightly oblong, I’d go with the spring loaded APCO accessory.
Post by Rich Eagle » Mon Sep 13, 2021 2:44 pm
I like the Apco's I have rebuilt and used.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Mon Sep 13, 2021 3:12 pm
Thanks, is there a way to get APCO's on faster? The cone shape makes it only possible to get a ratchet on for half the way then the edge gets too tight and you have to change to a wrench which is slow to get them on. I've only seen the grease cup type on my Touring does any one sell those?
Post by TRDxB2 » Mon Sep 13, 2021 4:44 pm
The spindle arm end looks a bit worn causing the gap. Don't know if an acceptable fix is a thrust washer (not a regular washer)
Post by Scott_Conger » Mon Sep 13, 2021 4:55 pm
The grease-cup version is a period accessory or a modified original cap
taking too long to put an APCO cap is a new one on me... :?
