WIRING HARNESS ROUTING
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Post by Professor Fate » Sat Sep 11, 2021 9:27 pm
Can someone please post some pics of proper generator/headlight wiring harness routing, from the firewall down the frame beyond the steering column frame attach point , on a '26? Do I need clips?
Thanks!
________________
**FATE**
Re: WIRING HARNESS ROUTING
Post by Scott_Conger » Sat Sep 11, 2021 9:31 pm
Professor Fate
Last Name: S
Post by Professor Fate » Sun Sep 12, 2021 12:45 pm
Anybody have an actual photo of their set up?
I'd like to see along the frame by the steering column.
________________
**FATE**
TFowler
First Name: Todd
Last Name: Fowler
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor Saloon
Post by TFowler » Sun Sep 12, 2021 10:14 pm
This is the wire routing on my 27 tudor. 2 clamps on drivers side...wire loom goes up to radiator ...then runs along base of radiator (3 metal tabs on radiator hold wire loom) to right hand side (generator and head lamp)
Professor Fate
Last Name: S
Post by Professor Fate » Sun Sep 12, 2021 10:35 pm
Thanks Todd.
Mine is routed like your pic now. Might add a clamp to hold it in place.
Thank you!
________________
**FATE**
Professor Fate
Last Name: S
Post by Professor Fate » Mon Sep 13, 2021 12:34 pm
All set!!!
________________
**FATE**
