Is this Threshold Correct?
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Sat Mar 23, 2019 8:28 am
Can someone post a photo of a correct threshold for a 23-25 Rear Touring Door? This photo is of my right rear threshold for my 1924, should the metal pieces be joined here or is this correct?
Looking down on the right rear threshold
Re: Is this Threshold Correct?
Post by DanTreace » Sat Mar 23, 2019 8:40 am
Correct, except typical production the wood filler pieces above the sill are tapered up and a bit more flush with the edges of the metal threshold at each upper corner. The exposed wood painted with body pieces installed.
Post by DanTreace » Sat Mar 23, 2019 9:02 am
View at rear seat heel panel
View at front seat backrest toe panel
IMG_3123 (600x450).jpg (92.62 KiB) Viewed 4690 times
Another view rear seat toe panel
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Sat Mar 23, 2019 10:14 am
Thanks Dan for posting those pics, a big help. Would you know what kind of wood those filler pieces are?
HornsRus
First Name: Charley
Last Name: Shaver
* REQUIRED* Type and Year of Model Ts owned: 1913
Post by HornsRus » Sat Mar 23, 2019 11:07 am
buy 23 wood was hard to get so most was pine. or any scrape on the floor.ha,ha. that's why they went to steel bodies. charley
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Sat Mar 23, 2019 1:10 pm
Hi Charley, did you get my list of bolts, nuts that I need? Daniel Snell
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Sat Mar 23, 2019 10:35 pm
Dan Trace, On this photo I have circled a lip that is on the narrow threshold below the door. Is this lip supposed to go into a slot on the wood rail below? Mine is just resting on the wood rail and there is a space below it.
Lip on Threshold
Lip on Threshold
Post by DanTreace » Sun Mar 24, 2019 5:02 am
Daniel. Isn’t a slot in the wood sill, that stamped metal threshold piece just folds over. Variations in assembly of parts will occur with our Model T’s!
HornsRus
First Name: Charley
Last Name: Shaver
Post by HornsRus » Sun Mar 24, 2019 9:52 am
yes i have your list! i will be working on it. charley
