Completing my manual horn with brass
joe.wal
First Name: Joerg
Last Name: Walther
Board Member Since: 2014
Post by joe.wal » Sun Sep 19, 2021 7:07 am
Since the horn on my 1916 T has lost it's brass part sometime in the last 105 years I now made a cone by myself as I did not find an original part.
From the 'bay' I got a fairly cheap trumpet and cut off the cone with an iron saw.
It does not have the perfect shape or diameter but does look fine enough for my taste.
After removing some lacquer from the rim of the horn I used a two component glue which should dry out transparent.
Result looks fine to me - will let it sit for a week to have the glue fully hardening and hope the construction will stand the vibrations ...
1916 Touring
Re: Completing my manual horn with brass
Post by Rich Eagle » Sun Sep 19, 2021 1:51 pm
Nice fix! Clever and it looks great.
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Sun Sep 19, 2021 2:37 pm
That looks great! Now you will not have to worry about the plating wearing thin.
Paul
Post by speedytinc » Sun Sep 19, 2021 9:46 pm
Ditto. Another trick for the archives.
You guys amaze me with some of your brilliant fixes.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sun Sep 19, 2021 10:14 pm
A few brass rivets would probably hold it on well and look good.
joe.wal
First Name: Joerg
Last Name: Walther
Post by joe.wal » Sun Sep 26, 2021 7:27 am
Highly appreciate your positive feedback.
The glue proofs very strong, first ride without problems and the new brass part shining in the sun.
1916 Touring
John Codman
Last Name: Codman
Post by John Codman » Sun Sep 26, 2021 12:14 pm
The horn looks great, but I would second the comment about brass rivets. I have never encountered any sort of chemical fastener (glue) that will stand up long-term to constant vibration. It may be six months or six years, but in my experience, you are going to lose that bell as it is presently secured. I have even seen FAA approved bonding agents fail. Ask any old-time flight instructor about Cessna 150 - 152 tubular landing gear steps.
