Info Wanted RUSHMORE SEARCHLIGHT
Professor Fate
Topic author - Posts: 773
- Last Name: S
Anyone know anything about the RUSHMORE SEARCHLIGHT? Used on cars? Model T's??
________________
**FATE**
**FATE**
- First Name: Dennis
- Last Name: Seth
Re: Info Wanted RUSHMORE SEARCHLIGHT
Professor Fate, If you would look at the center of you car hood you would see the light in question
Professor Fate
- Last Name: S
"Yes!!"
- Attachments
- 20210918_104823 (1) (1).jpg (10.31 KiB) Viewed 2339 times
________________
**FATE**
**FATE**
ahovey
- First Name: Austin
- Last Name: Hovey
- * REQUIRED* Type and Year of Model Ts owned: ‘11 Torpedo
- Board Member Since: 2014
Correct me if I am wrong but I don’t believe they were ever supplied on Model Ts out of the factory.
I have seen them on quite a few different brass cars, often luxury marques. At least on some Pierce Arrow’s I have seen them with plano convex lenses. The lense is flat on one side and convex on the outer side to help throw the light. Often the lense is made up of multiple piece of glass ~2” wide vertical pieces.
Google this - Rushmore Dynamo Works - lots of info
And there was a copy cat
Professor Fate
- Last Name: S
I found the light housing at a local flea Mkt yesterday. Cracked mirror and glass. No shaped lense glass as you mention. Mounting bracket was missing. Asking price $80. I'm tempted to run and grab it this a.m.
________________
**FATE**
**FATE**
pre15dale
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
That one is actually a head light. I can tell by the mounting bracket . All rushmores said search light on the chimney whether headlight or an actual search light. The search light model mount was made to swivel up and down and also had handle on the back. $80 Is a pretty good buy for one in that nice condition.
