Support Forum
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Post
by MichaelPawelek » Wed Oct 13, 2021 6:10 pm
MichaelPawelek on Sat Oct 16, 2021 7:39 pm, edited 1 time in total.
Dave Sullivan
- Last Name: Sullivan
- * REQUIRED* Type and Year of Model Ts owned: 1923
Post
by Dave Sullivan » Wed Oct 13, 2021 6:25 pm
Must have had stock in Imperial Brass..dave
MichaelPawelek
Post
by MichaelPawelek » Wed Oct 13, 2021 6:37 pm
The problem is that someone started at the tank and made all the runs and 90° bends to the carburetor not taking into consideration the carburetor would ever have to be taken off in the future. It is very stiff and precise but with no “Union” in the line.
Post
by speedytinc » Wed Oct 13, 2021 6:48 pm
I am seeing 3 "union/couplings". Looks like a mess of compression ring fittings.
Someone had a can full of brass fittings needing a purpose.
MichaelPawelek
Post
by MichaelPawelek » Wed Oct 13, 2021 6:56 pm
The two near the carburetor actually have threads on the back sides and tighten up as you try to unthread them. I’ve never seen this type of fittings before.
sweet23
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
Post
by sweet23 » Wed Oct 13, 2021 7:57 pm
When non mechanically incline people betterize things. I see it every day.
- Last Name: Hjortnaes
Post
by DHort » Wed Oct 13, 2021 10:01 pm
Probably worked at a hardware store.
Post
by Mark Gregush » Thu Oct 14, 2021 1:51 pm
I saw a 1926/27 setup on Facebook (can't find the picture now), that had all kinds of twist, turns, dogleg and filter(s). They, too, took something so simple and over complicated it!
- First Name: Dennis
- Last Name: Seth
Post
by perry kete » Thu Oct 14, 2021 2:06 pm
Perhaps his uncle was a plumber!
John Codman
- Last Name: Codman
Post
by John Codman » Fri Oct 15, 2021 10:07 am
Rube Goldberg is alive and well.
Post
by TXGOAT2 » Fri Oct 15, 2021 10:08 am
But... the installation is not complete!! It needs magnets and clothespins if it is ever to function properly... filters, filters, filters.... and where are the fuel pumps??
MichaelPawelek
Post
by MichaelPawelek » Fri Oct 15, 2021 10:41 am
Funny you should mention clothes pins. Most folks under 50 wouldn’t know what they are. I still have a shoe box full I occasionally use to hold small parts and hang things on the wall. Also to hold gaskets in place as I Permatex them up. Save any old ones you have. Like everything else the newer ones are stupid worthless.
Post
by TXGOAT2 » Fri Oct 15, 2021 10:47 am
I came across a website of someone who is making real clothespins that actually hold together and work. I can't recall how to access it. Some searching might turn it up, if it still exists.
Post
by Norman Kling » Fri Oct 15, 2021 10:53 am
He probably had to take it off very often! There is no sediment bulb and I didn't see anything like a filter in the line. Lots of joints which could catch sediment though.
John Codman
- Last Name: Codman
Post
by John Codman » Fri Oct 15, 2021 5:20 pm
MichaelPawelek wrote: ↑Fri Oct 15, 2021 10:41 am
I have some that I actually use to pin clothes to a clothesline. The clothesline uses no electricity, and is (in the SW Florida sun) just about as fast as a clothesdryer.
John Codman on Sun Oct 17, 2021 10:17 am, edited 1 time in total.
- First Name: Adrian
- Last Name: Whiteman
Post
by A Whiteman » Fri Oct 15, 2021 5:49 pm
Hey - It Works!
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Post
by ThreePedalTapDancer » Fri Oct 15, 2021 6:05 pm
I’ve seen several that look exactly like that. Every T I’ve bought in the past had similar” improvements” added to them in the past. I promptly remove them unless it’s a working era manufactured accessory. Otherwise it’s back to stock in order to make future troubleshooting easier.
Post
by TXGOAT2 » Fri Oct 15, 2021 7:25 pm
If you add a fuel pump or two you can then add a fuel pressure regulator.... maybe do a 2 stage setup with a high and low pressure pump and 2 regulators!
MichaelPawelek
Post
by MichaelPawelek » Fri Oct 15, 2021 8:01 pm
Well, The ground up rebuild on this Model T was done 21 years ago by someone in San Diego so I can take no credit for all this added mess!
Post
by Wayne Sheldon » Fri Oct 15, 2021 9:47 pm
I am not sure which would be worse? That mess? Or four feet of rubber hose cobbled in?
MichaelPawelek
Post
by MichaelPawelek » Sat Oct 16, 2021 7:44 pm
Post
by TXGOAT2 » Sat Oct 16, 2021 7:56 pm
Henry would approve.
FreighTer Jim
- Last Name: Jarzabek
- Board Member Since: 2008
Post
by FreighTer Jim » Sun Oct 17, 2021 9:14 am
Hi Michael
Looks Good !
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
