Mystery Bolts
AndreFordT
First Name: Andre
Last Name: Valkenaers
Mystery Bolts
Post by AndreFordT » Mon Apr 01, 2019 10:19 am
Hey All,
During the weekend I started a new project.
Repairing a 1915 touring with an accident.
On the right side of the hoghead I found two "Mystery Bolts".
Does someone out there have an idea why these bolts are there and what is the use of these bolts??
Photos in attachment.
Andre
Belgium
George Andreasen
Last Name: Andreasen
* REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Re: Mystery Bolts
Post by George Andreasen » Mon Apr 01, 2019 10:26 am
Ummmmm............over travel stops? Only thing I can come up with.
Re: Mystery Bolts
Post by RajoRacer » Mon Apr 01, 2019 10:28 am
I'd venture a WAG that it was an attempt to keep the brake band centered on the drum to pull both sides evenly - obviously the reverse bolt was too short or broken off ?
Re: Mystery Bolts
Post by RajoRacer » Mon Apr 01, 2019 10:29 am
I see that the reverse bolt had been sawed off !
First Name: Keith
Last Name: Townsend
Re: Mystery Bolts
Post by KWTownsend » Mon Apr 01, 2019 3:49 pm
It may have been equipped with outside band adjusters at one time.
Kerry
Last Name: van Ekeren
Re: Mystery Bolts
Post by Kerry » Mon Apr 01, 2019 5:45 pm
Or, an rusted up hogs that needed the shafts punched out for restoration, holes drilled then plugged up.
Re: Mystery Bolts
Post by Original Smith » Mon Apr 01, 2019 6:23 pm
Don't forget it's April Fools!
AndreFordT
First Name: Andre
Re: Mystery Bolts
Post by AndreFordT » Tue Apr 02, 2019 12:45 am
No, No, this is not a 1st April joke.
They are there.
The most believable reason is that the hoghead was very rusty. To push out the pedal shafts someone drill two holes and plug them with the bolts.
I will grind them flat and weld them at the outside to secure them.
Thanks.
Andre
Belgium
