Source for miscellanious Domed Bolts
ModelTWoods
Topic author - Posts: 1598
- First Name: Terry
- Last Name: Woods
Other than cylinder head DOMED BOLTS, does anyone know of a source for misc. sized domed bolts, like the ones supplied with Stromberg carburetors to mount them to the intake manifold? I have a Stromberg M-1 carb that didn't come with the bolts and they look to be smaller in diameter than the bolts furnished with an OF. I haven't checked with McMaster-Carr, but I doubt they have any.
- First Name: Henry
- Last Name: Lee
Re: Source for miscellanious Domed Bolts
Terry if you can give me length and sizes required.., I might have some in my bins.
Hank
Hank
ModelTWoods
- First Name: Terry
- Last Name: Woods
Thanks, Hank. I'll measure and get back to you.
If you can't find them, I use Allan socket head bolts to mount my carbs.
If Hank does not have them, you'll want to consider something else, as they are a custom fabrication these days...not a stock part
ModelTWoods
- First Name: Terry
- Last Name: Woods
Hank: 5/16" diameter x 1/2"-3/4" length (1" would even be OK; I'd just cut to length) 18 T.P.I. Need 2.Henry K. Lee wrote: ↑Fri Oct 22, 2021 12:42 pmTerry if you can give me length and sizes required.., I might have some in my bins.
Hank
ring gear bolts. Period correct, tall head. Safety wire for a cool detail. Can weld the holes up & round the heads also.
Don't know the sizes but Lang's has domed bolts for the Water Outlet and also for the front spring clip
https://www.modeltford.com/pl.aspx?t=s& ... Bts&page=1
My OF came with hex head bolts, with slots for a screwdriver, and were coarse thread. I lost one!!!!
- First Name: Henry
- Last Name: Lee
Email sent Terry.
Hank
Hank
- Last Name: Patrick
Try www.McMaster.com. Enter. “Dome-head bolts” (don’t forget the dash). They might have something you can use or give you ideas on something else that might work. Jim Patrick
- First Name: Henry
- Last Name: Lee
Nice set sent this morning!
