Looking for a ball bearing universal ball cap = ?
Michel
First Name: Michel
Last Name: VIN
Post by Michel » Thu Nov 04, 2021 3:04 am
Hi,
Is anybody knowing how to get the Model T part "Ball Bearing Universal ball cap, no machining to the tail shaft required" ?
Usual Model T parts suppliers, Lang's (Part 3369BBD), Snyder's, Mac's, Texas T .... say that they have been without getting any during the last 12 months
Would somebody have one (or several) available ? Or would know what factory it comes from ? I was told it is manufactured/made in the US
Some of our French mate are looking for this device for a while and we look forward more information on this Part
Thanks for your knowledge and advices on this subject
Regards
Michel
Last Name: Hjortnaes
Re: Looking for a ball bearing universal ball cap = ?
Post by DHort » Thu Nov 04, 2021 7:38 pm
You only need one gasket and it goes on the side facing the engine.
Bud Delong
First Name: Kenneth
Last Name: DeLong
Post by Bud Delong » Mon Nov 08, 2021 8:34 am
There are some who say you are lucky if you never find one!!!! Bud. :lol:
Post by speedytinc » Mon Nov 08, 2021 8:46 am
I am in that camp.
When you cut the ball (lessening the BALL joint function), Cut the minimum @ the top, Perpendicular to the ground as installed.
Anybody else see one of those brass units take a hard hit & break?
Post by Original Smith » Mon Nov 08, 2021 10:33 am
If you wish to break a transmission main shaft, go ahead!
Post by TRDxB2 » Mon Nov 08, 2021 12:38 pm
To be fair, you should explain what would cause that. I do see a difference in design of the two ball bearing units. One has a very short collar compared to an original or the other bearing model. That would concern me. In addition, how would one do a "press" fit of the ball cap bearing to the tail/main shaft such that flange of the ball cap would fit properly with just enough room for one gasket towards the engine? For these o work the shaft has to fit tightly on the bearing sleeve.
