I'm in process of putting on some body brackets on the sill runner for a 12. The sill runner is 2 3/8" tall and 1 1/2" thick. Where should the body brackets be mounted on the sill runner height wise? Should they be flush with the bottom? I marked some holes holding the bracket flush with the bottom of the sill runner and the step bolts head would overlap the bottom. Anyone with a 12 that could measure the location of the body brackets?
Mike
Body Bracket locations on Sill Runner for a 12
pre15dale
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Re: Body Bracket locations on Sill Runner for a 12
Mike, I I don't have a 12 but on my 09 my 10 and my 13 original body's they are all flush with the bottom of the sill. On both
My 14s, a touring and a roadster the brackets are 1/8 in above the bottom of the sill
