Reduce contact-fire on Trembler Coil buzzer
rainer
First Name: Rainer
Last Name: Hantsch
* REQUIRED* Type and Year of Model Ts owned: Model T Touring 1916, brass & black
Post by rainer » Sun Oct 31, 2021 6:53 am
Today I finished the re-assembly of my Lizzy.
Checking the spark firing sequence (1-2-4-3), I hand cranked slowly and watched which coil is active. Sequence is ok, but I see a relatively strong firing.
Is it possible to add a capacitor on the trembler coils directly? I mean in a way that I do not have to dig into the coil to replace the internal capacitor?
Model T Touring 1916 (brass & black), 95% original
I am from: AUSTRIA, EUROPE
Re: Reduce contact-fire on Trembler Coil buzzer
Post by speedytinc » Sun Oct 31, 2021 10:07 am
Yes. seen it done. Make sure it clears the coil box lid. My feeble memory says it can be placed out on a terminal post. Dont quote me on this. Might be worth confirm/deny. In fact, A coil wizard will be visiting . Ill ask directly.
Post by TRDxB2 » Sun Oct 31, 2021 10:47 am
I am not advocating doing this but it has been done by others as a temporary fix.
http://www.mtfca.com/discus/messages/50 ... 1424318130
Doing it the right way may be easier in the long run when trying to protect an external connected capacitor to the coil posts from shorting when securing the lid. The lid is needed to keep the coils form moving and loosing their contacts. Its also important to use the capacitor matched to the coil so maybe there lies the problem. http://www.mtfca.com/discus/messages/80 ... 1248132830
Some videos to replace the internal capacitor others
https://www.youtube.com/watch?v=FyqwOVLbuek
https://www.youtube.com/watch?v=B1zT53oBFck
rainer
First Name: Rainer
Last Name: Hantsch
Post by rainer » Sun Oct 31, 2021 11:51 am
Thank you so much.
I will try without hood if contact fire will strongly reduce with externally attached capacitor.
At Chaffin's we use a 0.47 uf, 400V polypropylene capacitor with a dV/dt rating of 6000.
If it works, I think about opening my ignition coils, otherwise I let it be. Therefore I am asking for the external cap before having unnecessary work.
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sun Oct 31, 2021 6:34 pm
Definitely a temporary fix, and only for an open circuit internal capacitor. If the internal capacitor is excessively leaky, then no amount of external capacitance will fix the problem. Also, if the internal capacitor is open circuit with an intermittent connection, if the connection comes good then the amount of capacitance is increased - not that it will stop the coil functioning.
Post by speedytinc » Sun Oct 31, 2021 10:58 pm
I did speak with my coil genus. Must be connected between upper & lower points. If you want to drill a hole or holes, you can in theory have 4 remotely mounted any where.
