Floorboards
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
Floorboards
What coating/paint should I use on my new floorboards? Were the factory boards painted?
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
Re: Floorboards
I used Por-15 on my floorboards.
It adhears really well and wears like iron.
It has a glossy finish.
Unless you park outside, with the top down, in the sun, full time,
there are no issues with the color becoming cloudy.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- Last Name: Humble
Re: Floorboards
26-27 floor boards were painted black at the factory, what particular black paint is up to you. I had good results with water based enamel from Home Depot.
