Placement of Small Bracket Under Oval Tank.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Mon Nov 15, 2021 3:02 pm
The current gas tank in my 25 Coupe does not have the small banana shaped bracket seen at the bottom of this picture. Is it supposed to sit in the bracket with two legs or one leg or is there supposed to be one of these brackets on both sides. Thank you.
mbowen
First Name: Miles
Last Name: Bowen
Re: Placement of Small Bracket Under Oval Tank.
Post by mbowen » Mon Nov 15, 2021 4:52 pm
I removed these brackets from my ‘25 touring tank just yesterday for painting. The banana-shaped part was under the single-footed bracket. No such piece under the two-footed bracket. I can’t say for sure that it’s correct, just how mine was put together.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Post by RajoRacer » Mon Nov 15, 2021 5:10 pm
Yes - bracket under the single leg only.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Mon Nov 15, 2021 5:15 pm
The loose bracket you ask about goes on the one bolt to frame side tank bracket under the gas tank.
Last Name: Strange
Post by CudaMan » Mon Nov 15, 2021 5:51 pm
I just looked under my 1924. Banana bracket on single leg only. :)
