Frank Van Ekeran. Are you OK?
Rob Patterson
Last Name: Patterson
* REQUIRED* Type and Year of Model Ts owned: '21 Canadian built Aust'n Bodied (Steenbohms) Touring & '15 Speedster
Board Member Since: 2003
Post by Rob Patterson » Sun Jan 06, 2019 9:23 pm
For several days now there's been a raging bushfire nearby to Frank's place in Victoria.
Just now I've noticed its been raised to "Emergency" status.
I hope he, his lot and his T's are all OK.
Rob
"When everything seems to be going against you, remember that the airplane takes off against the wind, not with it." HENRY FORD
Tim Moore
First Name: TIMOTHY
Last Name: MOORE
* REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Re: Frank Van Ekeran. Are you OK?
Post by Tim Moore » Sun Jan 06, 2019 9:42 pm
He e-mailed me 24 hours ago and did not mention any problems.
Tim Moore
Rob Patterson
Post by Rob Patterson » Sun Jan 06, 2019 11:55 pm
Some reports say that Firefighters have had to retreat...
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Mon Jan 07, 2019 1:47 am
No Problem Rob for Frank. The fire is moving away from his house and the township in a Sth Westerly direction. The fire was burning in a largely uninhabited area which included National park etc. Unfortunately it is now moving towards farms and residents have been advised to evacuate.Just enjoyed a cold beer with Frank and discussed why he cant log on to the new forum. You will hear from him again as soon as he is able. He will be keen to "discuss" some more with Hans about Tarrant and Duncan & Fraser!
Rob Patterson
Post by Rob Patterson » Mon Jan 07, 2019 2:28 am
Hi,
I have just had this email message from Frank and as aussie16 says, all is OK.
Cheers,
Rob
Hi Rob,
Thanks for you concerns, at this stage the fires are of no threat only
burning bush park land and pine plantations, no lose of housing etc, a
back burn seems to be the most concern that has got a little out of hand
several k's away.
I'm having trouble registering on the new forum at this stage, have
asked for Chris's help on that one.
Any way all's well.
Regards. Frank.
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Jan 07, 2019 4:27 pm
Over the registration problem so test post.
A bit smokey today but no wind as yet to be of any threat. ;)
Kerry
Post by Kerry » Fri Jan 11, 2019 4:10 pm
Still burning, 32,000 acres so far, it amazes me how many government departments and staff it takes to monitor this fire, they nearly out number the poor buggers fighting it!
