On a car, 4 rivets = 1924 & earlier; 2 rivets = 25-27. Does this apply to trucks also?
TT hand brake quadrant?
Topic author - Posts: 7413
kmatt2
- First Name: Kevin
- Last Name: Matthiesen
Re: TT hand brake quadrant?
Yes the TT switched over to 2 rivets in 1925. Also for general information, the TT hand brake uses a taller cam lever due to the taller frame if you are looking for a hand brake at a swap meet.
Notice too, the lower photo is an early 1925 frame, using up the last of the 1924 style frames.
