Need suggestion for oil leak in hogshead
Topic author - Posts: 2958
- Last Name: Hjortnaes
My T has developed some leaks and I would like to determine if it is mainly caused by the pedals in the hogshead. I think I will need to install seals in the hogshead, but that is down the road. What would you suggest I do to make a temporary fix? Thank you.
Re: Need suggestion for oil leak in hogshead
Give everything a good wipe down. Check your inspection cover and bendix cover. For now a drip pan under the car.
