Chicago Aux. Trans.
First Name: craig
Last Name: leach
Chicago Aux. Trans.
Post by Craig Leach » Mon Feb 07, 2022 9:31 pm
Hi Guys,
A freind just picked up a Chicago Aux. trans is the pocket (center of main shaft beraing ) like a Warford made out of unobtainium or is it a standard type bearing that is available? Thanks.
Carig.`
Dropacent
Last Name: Morsher
Re: Chicago Aux. Trans.
Post by Dropacent » Mon Feb 07, 2022 10:43 pm
Craig, I was up to my elbows in them a couple years ago here. ( thanks mike !). There are at least two different types, one appears to be pretty common bearings and the other was a real wild style, something prehistoric looking. They WERE NOT interchangeable, and I had enough of the good modern looking ones to complete my mission. I forget now if the cases were interchangeable. Hope this helps a little.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Feb 07, 2022 11:30 pm
Tim,
The way my luck goes this will be a jarasic park one. I forgot to ask what the length is on them are they the same as a warford? This may turn out to be one of those I should have said gee I cant even spell model T things.
dang.1922
Last Name: Greger
Post by dang.1922 » Tue Feb 08, 2022 6:33 am
I have 2 Chicago transmissions and the cases are different. The input shaft bearing bore is larger on one. Both use the same bearing in the center. Bearings were still available last fall, and I think that bearing is the same as the cluster gear bearings. Dan
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Tue Feb 08, 2022 9:56 am
If I remember right the case's with patent pending on them had the oddball bearings.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Tue Feb 08, 2022 12:28 pm
Side request - does anyone happen to have a spare input shaft for a Chicago? I really like the transmission but the square part of the shaft the goes into the 4th main is beat up giving excess lash in the driveline.
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Feb 09, 2022 9:23 am
Thanks Guys,
Looks like it will be on the bench soon.
