Rivet shank size
Caswell
Topic author - Posts: 449
- First Name: Dean
- Last Name: Brevit
Rivet shank size
Just started taking my car apart and I will be removing the running board brackets tomorrow or the day after, I'm going to center punch them and drill the rivet head centers, does any one know the rivet shank size, I could use different size bits until I get the right one but if somebody knows it would help, trying to not over drill bracket or frame. Pictures below of bracket type, brackets will not be reused (speedster).
RGould1910
- Last Name: Gould
Re: Rivet shank size
1/4" shank I recall
Aussie16
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 RHD Canadian Touring 1916 Pickup 1926 Fordor 1925 Dalgety Tourer 1916 Speedster
Rather than drilling, If you have a good heavy cold Chisel, chiselling the heads off from inside the chassis rail is easy. !/4 " is correct. I but the rivets from Langs.
My approach would be to grind the heads flush with the running board bracket, then drive the rivet out with a punch. If they're still too tight, drill a smaller hole in the rivet, but not all the way through. Put a punch in the blind hole and drive the rivet out. The smaller blind hole allows the rivet to collapse. This way, you don't mess up the holes in either the bracket or the frame by being just a bit off with a full sized drill.
Caswell
- First Name: Dean
- Last Name: Brevit
Thanks all, I removed them last night, spring loaded punch, 1/8" pilot hole followed by 1/4" drill, rivet heads all fell off.
