Ed Huff and his first magneto
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Wed Dec 29, 2021 2:09 pm
I was going to put this on the other thread, but didn't wish to detract from the Huff information in that thread. However, mention was made of the original, or first Huff magneto, so I thought a fresh thread warranted.
I've had the good fortune to possess two Holley Magnetos, a 1906 and 1907 version. There was also a 1908 version, and each was standard equipment on the three year Model K Ford.
The concept the first Huff magneto began with Nikola Tesla. From Wikipedia:
"Most ignition systems used in cars are inductive discharge ignition (IDI) systems, which are solely relying on the electric inductance at the coil to produce high-voltage electricity to the spark plugs as the magnetic field collapses when the current to the primary coil winding is disconnected (disruptive discharge). In a CDI system, a charging circuit charges a high voltage capacitor, and at the instant of ignition, usually determined by a crank position sensor, the system stops charging the capacitor, allowing the capacitor to discharge its output to the ignition coil before reaching the spark plug."
As with the Model T magneto, Ed Huff was inventor of what became the first working CDI system in the world. While Tesla patented the theory, no one developed the switching system to use the magneto before Huff. As with the later T mag, Huff applied for the patent, but it was also assigned to Henry Ford on the patent application. The patent was applied for in the summer of 1905. The magneto was already in use on the Ford six cylinder racer, first seen by the public in January 1905.
The first variation of the magneto had no advancing system, and this was changed in the 1907 and 08 versions.
Below is a photo captured from the video link below it, showing the spark, across about 3/4th of an inch at 300 rpm. The spark is so hot it will jump up to 3 inches at higher rpm, and I am able to crank start the Model K on magneto with this unit.
Link showing Bruce V. S. running the mag with a drill at 270 rpm. The magneto is putting out about 300 volts at this rpm:
https://www.dropbox.com/s/1bx3ad41cojqp ... g.mp4?dl=0
Henry Ford and George Holley collaborated to produce the magneto, and in addition to all Model K, it was standard equipment on Grout automobiles. Other car makers, including the Thomas Forty offered the Holley magneto as optional equipment. Below is a letter from George Holley to Henry Ford dated Dec 14th, 1905. Holley describes his efforts to market the magneto to other car makers, as well as comparisons with other makes of mag:
Courtesy of The Henry Ford, all rights apply.
Below is a photo of Frank Kulick, Fords race car driver, seated on the 1907 six cylinder racer. Just forward of his right foot one can see the distributor head and magneto body, mounted vertically on the racer. This is same magneto used to lead Ford Model K to several racing and hill climb victories, including the world 24 hour speed record set in June, 1907.
Photo courtesy of the Kulick family.
If you watch the video, you can see how incredibly hot the spark is. The effectiveness of the magneto is also it's biggest downside. It's so hot when any moisture or insulation weakness occurs, the magneto "burns itself up." Bruce just rebuilt mine for a second time, and we're ready to use the mag again.
One unique feature of this magneto is that it will work when the magneto portion of the device fails. There is a two way ignition switch, and you can switch the mag on, off, or to battery. On battery, the magneto acts as a distributor and master coil system, using one coil and capacitor to distribute the spark, much the same way a modern distributor does.
I think the other downside of this magneto was it's expense. As George Holley mentioned in his letter to Henry Ford, there were too many parts and it was expensive to make.
Mike Kosser reviewed the wiring diagrams of the mag several years ago, and pointed out that this is a capacitive discharge ignition system. As far as I can tell, no production automobile offered a CDI as standard equipment again until the late 1950's.
Been Here Before
First Name: George John
Last Name: Drobnock
Re: Ed Huff and his first magneto
Post by Been Here Before » Wed Dec 29, 2021 4:42 pm
""The concept the first Huff magneto began with Nikola Tesla. ""
Thank you for the post.
When I suggested a connection between Tesla and Edison...well it was funny.
Wiki - ""U.S. Patent 609,250 - Electrical Igniter for Gas Engines - 1898 August 16 - Ignition system principles used today in automobiles; Operation of a machine that requires a spark, flame, or any other similar effect; More certain and satisfactory for use of and control by the machine or apparatus; Charging and discharging a condenser through switch or commutator.""
Wiki- ""U.S. Patent 487,796 - System of Electrical Transmission of Power - 1892 December 13 - Alternating current generator consisting of independent armature-circuits formed by conductors alternately disposed; Currents developed differ in phase and the field magnet poles in excess of the number of armature-circuits; Motor having independent energizing circuits connected to the armature-circuit of the alternating current generator; Rotating magneto-electric machine yielding a given number of current impulses or alterations for each turn or revolution; Poles which in number are less than the number of current impulses produced in each motor-circuit by one turn or revolution; Multipolar alternating-current machine.""
Thank you again.
Post by Scott_Conger » Wed Dec 29, 2021 5:59 pm
George, on your other thread, You did not suggest a connection between Tesla and Edison...and Huff, you specifically suggested that a Tesla motor/generator design was incorporated into the Huff magneto.
Then you proceeded to trot out a Tesla patent which timed a battery ignition to a compression stroke on and engine, and a second Tesla patent involving a generator-created electrical output transmitted across to electric motors of varying pole-counts creating different output speeds. Neither of these patents have ANYTHING to do with the Huff design save for the fact that all 3 patents are devices that contain wire as a component element.
Yes, Tesla electrical designs and concepts being revolutionary at the time, all spurred further adaptations of all manner of things electrical among thousands of inventors, resulting in patents on things from Ford Magnetos, to hand mixers, and everything in between, but to suggest that somehow a specific Tesla design is specifically in the Huff magneto and then encouraging discussion of "conspiracy theories" about it is just plain, well...
That was really too bad, as you started that thread with some interesting information and then shortly after proceeded to drive it out into left field.
I suspect that the superiority of buzz-box adjusted coils thread just ran out of steam and this is the new soap-box.
I do appreciate the fact that Rob has taken the time to show and explain about earlier Ford/Huff magnetos...a subject that I do not recall ever seeing, anywhere. Hopefully the thread will continue with more on-topic discussion...and along that line, I suppose I should apologise for aiding in it's drift.
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Wed Dec 29, 2021 6:51 pm
A few more Huff-Holley-Ford tidbits.
Many knew Huff was Henry Ford's mechanician on his first racer, Sweepstakes, and held the carb open when HF made his world record on ice in early 1904. What I suspect few knew was Huff was driving 999 when Frank Day was killed driving Arrow in the early fall 1903 at the Milwaukee fairground track:
George Holley (passenger this 1906 Ford Model K) owned a Model K:
The Holley Foundation website contains this mention of the Ford's six cylinder 24 hour victory using a Holley Magneto. Unfortunately the make "Ford" isn't included:
This 1907 ad mentions the Holley Magneto available as an option with the Thomas Forty:
