Fun Projects Technical Library
QGolden
First Name: Quinn
Last Name: Golden
Post by QGolden » Wed Dec 29, 2021 9:59 pm
Hello
Does anyone know if the Fun Projects Technical Library was ever reposted anywhere?
Specifically looking for “Model T Ignition Coil” parts 1-3.
Thank you.
dykker5502
First Name: Michael
Last Name: Deichmann
Re: Fun Projects Technical Library
Post by dykker5502 » Thu Dec 30, 2021 1:40 am
I saved them in time:
The Model T Ignition Coil - Part 1.pdf
(2.57 MiB) Downloaded 334 times
The Model T Ignition Coil - Part 2.pdf
(2.46 MiB) Downloaded 220 times
The Model T Ignition Coil - Part 3.pdf
(3.8 MiB) Downloaded 234 times
Ford Model T 1914 Touring
QGolden
First Name: Quinn
Last Name: Golden
Post by QGolden » Thu Dec 30, 2021 2:10 am
Awesome! Thank you so much! I started building Model A Speedsters a long time ago, and tended to bookmark rather than download documents. Going back now, so many of those valuable sites are gone. I too save everything I come across now.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Thu Dec 30, 2021 6:14 am
Well done Michael!
Maybe this Forum should have a library of worthy documents.
Just consider how much time and effort might be saved if we could just send people to read those three!
jab35
Last Name: Bartsch
Post by jab35 » Thu Dec 30, 2021 10:58 am
Chris is absolutely right, the FunProjects (RIP) technical information is right up there with Vowell Art in terms of accuracy, relevance, and value to the Model T community, and should be archived in the MTFCA website. jb
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Thu Dec 30, 2021 9:57 pm
This link will take you to the last image of the website in 2016. Unfortunately none of the documents appear to be there
https://web.archive.org/web/20161012003 ... hinfo.aspx
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Thu Dec 30, 2021 10:02 pm
http://www.funprojects.com/pdf/HCCTManual.pdf
http://www.funprojects.com/pdf/WheelpressA2.pdf
https://web.archive.org/web/*/http://ww ... s.com/pdf/*
On the last link, click the item you want to see, then click the date highlighted on the calendar. It should pull it up for you. If you click the one for speedometer, you get a firewall that shows the typical speedo mounting area
Last Name: Hjortnaes
Post by DHort » Thu Dec 30, 2021 10:29 pm
William
I get Internet Archive Wayback Machine website and it displays a 2010 calendar.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Fri Dec 31, 2021 2:11 pm
William
I don't think it matters what year the calendar shows just as long as you click on one of the highlighted dates. On the list link I provided (Third link), it tells you how many times that particular article was captured and the calendar range dates.
For example, the HCCT pdf. That was captured two times from March 2006 to March 2016
Ron Patterson
Post by Ron Patterson » Fri Dec 31, 2021 6:33 pm
Looks like "Wayback Machine" requires some payment to see the items to support the cost of their site?
Ron Patterson
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Fri Dec 31, 2021 10:40 pm
Ron Patterson
I have no idea where you came up with that. I look at it all the time and don’t pay a dime.
Joe Voller
First Name: Joe
Last Name: Voller
* REQUIRED* Type and Year of Model Ts owned: 1924 pickup 1922 centerdoor
Post by Joe Voller » Sat Jan 01, 2022 9:43 pm
it doesnt work for me ,i only get 1 date that lights up in2010 and get error on that date
