Speedster lowering kit.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Mon Jan 10, 2022 9:57 am
Yesterday I get home with a new speedster project.
The frame have a lowering kit on it.
Do any one know more about this kit?
Andre
Belgium
Re: Speedster lowering kit.
Post by TRDxB2 » Mon Jan 10, 2022 11:26 am
Rear axle method similar to several here. Note the wood block in the frame member to prevent distortion. Most interesting is what looks like a braket to lower the body or? Are ther others on the fram?
12 leaves on the front, heavy leaf spring clamps and bolts, likely another wood block in the cross member to prevent distortion.
TeveS-Nor Cal
Last Name: Straw
Post by TeveS-Nor Cal » Mon Jan 10, 2022 12:09 pm
Good looking lowering kit. Loose about half the spring leaves.
Post by Jerry VanOoteghem » Mon Jan 10, 2022 12:37 pm
Very nice kit! Funny that the original builder added so many spring leaves to the front that it seems to have cancelled out the lowering effect of the bracket.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Mon Jan 10, 2022 7:56 pm
Good looking castings. Is it really only two bolts in shear holding the front end? If so it would be appropriate to call it a suicide front end.
Andy
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Jan 10, 2022 10:37 pm
The rear spring is equally overdone... must have been a “low boy” 😉
The brackets are super cool! Would love to get some better detail pics when you get them off the chassis
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Jan 10, 2022 10:53 pm
Yes, Kool stuff I’ve never seen before.
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Tue Jan 11, 2022 6:47 am
First time seeing these for me as well, great looking brackets. Many were homemade, may have been an expensive alternative back then and not popular, thus the rarity?
