Where might a find metal strips for the floor of my 1925 bed.
I need the kind that are not drilled.
Thanks,
Clay
25 bed strips
Re: 25 bed strips
Appears Lang's has them - no longer with holes https://www.modeltford.com/pl.aspx?t=s& ... ips&page=1
Snyders https://www.snydersantiqueauto.com/sear ... bed+strips
Not sure if these are the same - length, shipping charges (ouch)
Speedway has Stainless Steel but not sure if the same https://www.speedwaymotors.com/Speedway ... gIeKfD_BwE
Summit racing looks to have the same https://www.summitracing.com/parts/mrk- ... gLLZ_D_BwE
eBay https://www.ebay.com/sch/cstreet_supply ... 3561.l2562
david_dewey
- Last Name: Dewey
Re: 25 bed strips
Actually, the authentic 1925 bed strips are not available, they are different than the 26 & on strips. The center recessed area on them is not flat, but convex, and Henry soon realized that put the carriage bolt heads higher than the ribs on either side, making it difficult to slide things in and out of the bed.
T'ake care,
David Dewey
David Dewey
- Last Name: Strange
Re: 25 bed strips
Here are some links to older threads about 1925 pickups:
http://www.mtfca.com/discus/messages/82 ... 1543491186
http://www.mtfca.com/discus/messages/25 ... 1347652390
Re: 25 bed strips
David, you beat me to it!
