connecting rod pin bolts
DonH
Topic author - Posts: 47
- First Name: Don
- Last Name: Hanson
- * REQUIRED* Type and Year of Model Ts owned: 1925
should the bolt holding the pin rod face the front of the piston or the rear?
DonH
- First Name: Don
- Last Name: Hanson
Re: connecting rod pin bolts
I think the bolt should face the cam side of the engine and instead of cotter key, wire bolt to rod.
Kerry
- Last Name: van Ekeren
Face the cam shaft, wiring the bolt to the rod has been known to come a drift and end up in the magneto, cotter pin or use a spring washer.
Faces the camshaft. the slot in the piston faces away from the cam. The cotter pin is placed in such a way that the folded end is against the rod so the bolt cannot turn.
DonH
- First Name: Don
- Last Name: Hanson
thank you all for your help!!
