connecting rod pin bolts
DonH
First Name: Don
Last Name: Hanson
* REQUIRED* Type and Year of Model Ts owned: 1925
Post by DonH » Wed Feb 02, 2022 6:41 pm
should the bolt holding the pin rod face the front of the piston or the rear?
DonH
First Name: Don
Last Name: Hanson
Re: connecting rod pin bolts
Post by DonH » Wed Feb 02, 2022 6:59 pm
I think the bolt should face the cam side of the engine and instead of cotter key, wire bolt to rod.
Last Name: van Ekeren
Post by Kerry » Wed Feb 02, 2022 8:20 pm
Face the cam shaft, wiring the bolt to the rod has been known to come a drift and end up in the magneto, cotter pin or use a spring washer.
Post by Norman Kling » Wed Feb 02, 2022 8:49 pm
Faces the camshaft. the slot in the piston faces away from the cam. The cotter pin is placed in such a way that the folded end is against the rod so the bolt cannot turn.
DonH
First Name: Don
Last Name: Hanson
Post by DonH » Thu Feb 03, 2022 10:49 am
thank you all for your help!!
