Starter Bendix Question
Plankhill
Topic author - Posts: 141
- First Name: Brendan
- Last Name: Doughty
- * REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Are short nose ones earlier than the long nose ones or the other way around?
Re: Starter Bendix Question
Believe the one on the left is Model A.
The one on the right is correct for all. The left is a close replacement. Better then not, but not quite right. Cant speak to model A usage.
Plankhill
Not Model A Came off a Model T .
My post was completely wrong and has been retracted
Kevin Pharis
- Last Name: Pharis
Model A starter shafts are larger diameter than a T. Seems to me T is 1/2”, and A is 5/8”...
BobD
- First Name: Bob
- Last Name: Doris
Early Model A's with the Abell starter drive had 1/2" shaft. From Oct. 1928 on, the 5/8" Bendix to end of production.
Kevin and BobD
you are right and I was completely wrong. So wrong, that I revised my post to the extent that I could
The Bendix drive head for the one on the left is a bit longer than T and uses a different lock bolt depth too, still think one on left is early Model A.
BobD
- First Name: Bob
- Last Name: Doris
Early Model A Abell starter drive.
