1912 Radiators
1912 Radiators
Post by Original Smith » Mon Feb 21, 2022 11:26 am
Need to know some facts, not guesses! When did Ford start punching the holes in the radiator side panels for the rubber headlight tubing? Could it have been about the same time they started stamping Made in USA under the Ford script?
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Re: 1912 Radiators
Post by rickd » Mon Feb 21, 2022 2:42 pm
From page 603 of the CD encyclopedia, Radiator section- "In mid 1912 holes were added in the sides for the gas lamp hose, with a soldered-in-place pipe from side to side for the headlamp gas. "Made in USA" under the "Ford" script was added about April 16, 1912."
Jim Suter Virginia
First Name: Jim
Last Name: Suter
* REQUIRED* Type and Year of Model Ts owned: 1916 T Touring
Re: 1912 Radiators
Post by Jim Suter Virginia » Mon Feb 21, 2022 4:36 pm
The New Version of the Encyclopedia under " Alpha Section", " P-R" and click on "Radiators", you will find the heading "Evolution of Brass Radiators by Trent Boggess. In the 8th. paragraph down, starting as," In 1912 holes were added in the radiator for the gas lines". It continues on with dates. Larry, I hope this will answer your question.
