What kind of Carbs are these?
Bryce S.
First Name: Bryce
Last Name: S
Post by Bryce S. » Sun Mar 13, 2022 4:52 pm
Hello all,
I recently went through some boxes of my father's and have found many carbs and was kind of wondering if anyone could tell me about each of them and if they are of any value in the T world.
Bryce
Joe Bell
First Name: Joe
Last Name: Bell
Re: What kind of Carbs are these?
Post by Joe Bell » Sun Mar 13, 2022 5:30 pm
The second one is a simmons straight thru, that last looks like a Chebby.
Bryce S.
First Name: Bryce
Last Name: S
Post by Bryce S. » Sun Mar 13, 2022 5:34 pm
I forgot to post this one.
Post by Norman Kling » Sun Mar 13, 2022 6:44 pm
That Tillotson looks like a carburetor made to fit a Model A. Not an original carburetor, but one which was available for aftermarket use on the Model A.
Post by Allan » Sun Mar 13, 2022 9:20 pm
The first is marked Zenith, but I am not familiar with them for a T. However, even though it is on a T manifold, I wonder how the width of the unit would fit inside the frame rail. Others may be able to shine a light on it.
Last Name: Gregush
Post by Mark Gregush » Sun Mar 13, 2022 10:32 pm
The top carb, if you look close at the 2ed photo, looks like a plug on the other side from where the fuel bowl is now mounted. Might just need to swap the fuel bowl to the other side. Some of the Zenith carbs like that, you could mount the fuel bowl in different configurations. Maybe? ;)
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Mar 13, 2022 11:07 pm
# 4 & #5 I think are carters for chevrolet. #6 is a after market for Model A. The first is very interesting would love to know more.
Craig.
Bill Coyle
First Name: Bill
Last Name: Coyle
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by Bill Coyle » Mon Mar 14, 2022 10:11 am
The DRJH-0 Carter with the Brass bowl is for the 1928 Pontiac. It's very similar to the Chevrolet except the mounting flange's bolt pattern is rotated 90 degrees.
Bill
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Mar 14, 2022 11:22 am
Good eye Bill.
Craig.
Bryce S.
First Name: Bryce
Last Name: S
Post by Bryce S. » Wed Mar 16, 2022 6:58 am
Very interesting. My dad was in A LOT of hobbies while I was growing up and unfortunately since my parents were divorced I had only seen him every other weekend. The times we did have were nothing but pure fun and enjoyment. I think that's the hardest part about losing a parent is when you have to go through their stuff and you start finding all of these things and they aren't there for you to be able to ask those questions. Every time someone passes away a library burns. That phrase couldn't be anymore true. I appreciate all of the information on these. Now if I could only find out what the heck that Zenith carb is.
Bryce
