I am building a hand crank coil tester. I have 2 coil rings both check out good
Using a battery charger and hacksaw blade as well as a compass. Magnets are
Charged
I can only get 3 volts out if it any advice?
Coil tester
- First Name: BOB
- Last Name: CASCISA
Re: Coil tester
Three Volts at hand crank speeds is about right.
The voltage doesn't matter to the ignition coil as it is a current operated device.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- First Name: Hal
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: '22 TT Stake Bed, '18 Touring (Hers)
Re: Coil tester
A lot of them don't even have volt meters. Mine doesn't. You might improve voltage a bit by closing the gap between the magnets and field coil. With the low speeds and lack of vibration associated with a HCCT, you don't have to have as large a gap as on a car.
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Re: Coil tester
When it is finished, how about a picture?
Topic author - Posts: 239
- First Name: Philip
- Last Name: Thompson
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
Re: Coil tester
thanks guys i got it going last night i had it wrong. it sparks nicely now i need to order some gauges i have been using my simpson
multi meter. i will post pics when i get it painted up. philip
