connecting rod dimensions
johnr
Topic author - Posts: 62
- Last Name: Delamater
- * REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Need the center to center dimension to bore my connecting rods.
John
John
Kerry
- Last Name: van Ekeren
Re: connecting rod dimensions
7 inches/CtoC
BobShirleyAtlantaTx
- First Name: Bob
- Last Name: Shirley
. What are you using to cut your babbitt?
johnr
thank you for the dimension.
will be boring on a bridgeport mill with a
criterion boring bar.
thanks john
thanks john
Harry Lillo
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
Has anyone experienced an appreciable difference in the lengths of Model T connecting rods?
Harry Lillo
Harry Lillo
Kerry
Many a time, it all depends on who has machined them. I recommend never mix them from suppliers. More than once I have found when fitting a Z head that it's not the casting at fault when a piston hits but the length of the rod. A local club member had built a cut away engine using a random of parts and ran slowly with an electric motor. pointing out to others, can you see what's going on here? and then pointing out to them that as much as an 1/16" in piston travel TDC difference.
Harry Lillo
- First Name: Harry
- Last Name: Lillo
Thanks Frank,
I can appreciate differences in center to center machined distance or length .
I should have been clearer with my question..........
Has anyone noticed any appreciable differences in the un-babbitted rods?
(Center to center distance of rods without any babbitt in them)?
Harry
Harry
Kerry
And again yes, if the parting line has been filed on the rod, not just the cap.
Looks like a "Check everything twice" situation.
