connecting rod dimensions
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Thu Apr 07, 2022 6:52 pm
Need the center to center dimension to bore my connecting rods.
John
Kerry
Last Name: van Ekeren
Re: connecting rod dimensions
Post by Kerry » Thu Apr 07, 2022 7:45 pm
7 inches/CtoC
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Thu Apr 07, 2022 9:16 pm
. What are you using to cut your babbitt?
johnr
Post by johnr » Thu Apr 07, 2022 9:27 pm
thank you for the dimension.
will be boring on a bridgeport mill with a
criterion boring bar.
thanks john
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Thu Apr 07, 2022 9:49 pm
Has anyone experienced an appreciable difference in the lengths of Model T connecting rods?
Harry Lillo
Kerry
Post by Kerry » Thu Apr 07, 2022 10:01 pm
Many a time, it all depends on who has machined them. I recommend never mix them from suppliers. More than once I have found when fitting a Z head that it's not the casting at fault when a piston hits but the length of the rod. A local club member had built a cut away engine using a random of parts and ran slowly with an electric motor. pointing out to others, can you see what's going on here? and then pointing out to them that as much as an 1/16" in piston travel TDC difference.
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Thu Apr 07, 2022 10:54 pm
Thanks Frank,
I can appreciate differences in center to center machined distance or length .
I should have been clearer with my question..........
Has anyone noticed any appreciable differences in the un-babbitted rods?
(Center to center distance of rods without any babbitt in them)?
Harry
Kerry
Post by Kerry » Thu Apr 07, 2022 11:25 pm
And again yes, if the parting line has been filed on the rod, not just the cap.
Post by TXGOAT2 » Fri Apr 08, 2022 8:34 am
Looks like a "Check everything twice" situation.
