Please identify this wire wheel
Tparts
First Name: Don
Last Name: Lang
* REQUIRED* Type and Year of Model Ts owned: Multiple years
Post by Tparts » Tue Jan 06, 2026 1:56 pm
Looking for information on the manufacturer of these wheels. They have an odd tapered hubcap.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Please identify this wire wheel
Post by Kevin Pharis » Tue Jan 06, 2026 5:49 pm
Must be spindle mount…? What’s the inside of the wheel center look like?
Tparts
First Name: Don
Last Name: Lang
Post by Tparts » Thu Jan 08, 2026 11:59 am
It’s a Hub mount
Tparts
First Name: Don
Last Name: Lang
Post by Tparts » Thu Jan 08, 2026 12:06 pm
Photos of the hub and wheel
Tparts
First Name: Don
Last Name: Lang
Post by Tparts » Thu Jan 08, 2026 12:19 pm
Found the name
Tparts
First Name: Don
Last Name: Lang
Post by Tparts » Thu Jan 08, 2026 12:30 pm
Rear hub photo
Post by RajoRacer » Thu Jan 08, 2026 1:56 pm
And, that would be, Don ??? I surely can't make it out !
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Thu Jan 08, 2026 1:58 pm
To my eye, it says "Universal Welding Co".
Keep crankin',
Eric
Post by DanTreace » Thu Jan 08, 2026 4:21 pm
Universal Welding Company, St. Anne, IL
Wheel photos posted show a bit different style, Maybe Universal Welding did a later design change to the wheel lug mounts?
Or?? Universal Hubs were used to mount different wire wheels without lugs? As those hubs are missing lugs and just have bolt heads to cover the holes
Universal hub .jpg (113.57 KiB) Viewed 911 times
Universal .jpg (189.06 KiB) Viewed 911 times
Tparts
First Name: Don
Last Name: Lang
Post by Tparts » Thu Jan 08, 2026 8:07 pm
Thank you Dan. The “Universal Wire Wheels” you show use a stock Ford wood wheel hub. They were the same design as what John McClaren used with his wheels. The style that I have shown must be very rare as I’ve never seen them before.
Post by RajoRacer » Thu Jan 08, 2026 8:30 pm
Thanks Fellas !
Post by Jerry VanOoteghem » Fri Jan 09, 2026 8:32 am
They're apparently a "knock-off" version. Cool!
Tparts
First Name: Don
Last Name: Lang
Post by Tparts » Fri Jan 09, 2026 2:21 pm
I’m in need of one more rear hub, wheel, and cap.
Mark Herdman
Last Name: Herdman
Post by Mark Herdman » Sat Jan 10, 2026 10:04 pm
I had some rough ones of these but unfortunately sold to someone to make a set some time ago.
