27 Roadster rear fender mounting bolts
Eric Sole
First Name: Eric
Last Name: Sole
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
Post by Eric Sole » Mon May 02, 2022 5:11 pm
Some owners say their 26-27 rear fenders are mounted with a bolt threaded into a caged nut on the body. I'm not sure if this is the place they're referring to but my 27 Roadster doesn't look like it ever had any caged nuts at the bolt holes.
The parts book shows a bolt, nut, plain washer and lock washer for this job.
Screenshot 2022-05-02 at 22.55.55.png (53.05 KiB) Viewed 1168 times
Are the holes marked in the picture the ones that could have either caged nuts or a bolt and nut?
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Re: 27 Roadster rear fender mounting bolts
Post by GG Gregory » Mon May 02, 2022 5:28 pm
The Turtle Deck is mounted with cage nuts at the top of the backrest area, not the fenders
Eric Sole
First Name: Eric
Last Name: Sole
Post by Eric Sole » Tue May 03, 2022 3:46 pm
I had that all wrong. Thanks for the heads up. Now it makes sense.
