How much torque?
WayneJ
Last Name: Jorgensen
How much torque?
Post by WayneJ » Thu Apr 28, 2022 12:58 pm
How much torque for a wrist pin bolt, and how much for rod castle nuts?
Thanks!
Wayne Jorgensen, Batavia, IL
1918 Runabout
Re: How much torque?
Post by Allan » Fri Apr 29, 2022 12:47 am
Perhaps more important than the torque applied to the wrist pin bolts is how that torque is applied. The piston/rod assembly needs to be held by the wrist pin when torquing the pin bolt. I have two dummy spiggots which go in each end of the wrist pin, and then the whole is held in a vice while the bolt is tightened. Otherwise you run the real risk of twisting the rod if it is held while the bolt is tightened.
Hope this helps.
Kerry
Last Name: van Ekeren
Post by Kerry » Fri Apr 29, 2022 3:33 am
Some who like to use a torque value say 30lbs. I still do it Henry's way of by feel, Also as Allan has posted, hold by wrist pin when tightening the bolt, the pin is hollow so slide onto a phillips screw driver in a vice, also remember that the wrist pin bolt faces the cam shaft when assembling engine.
Post by Mark Gregush » Fri Apr 29, 2022 3:45 am
I use a piece of rod held in the vice and go by feel also, using an original Ford wrench.
Adding: Forgot because I have not used it yet, I have a piston vice.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Fri Apr 29, 2022 4:23 am
I use this ;
Toon
Post by Allan » Fri Apr 29, 2022 5:56 am
Just like mine Toon. They hold the pin tightly with no slop at all.
Post by RajoRacer » Fri Apr 29, 2022 10:50 am
I also use a piston vice & a rod through the pin. Rod bolt nuts I also hand tighten by feel - I assume if one's intent on utilizing a torque wrench, I believe a grade 5 bolt is 6-8 lbs. per 1/8" - Model T rod bolts are 3/8" so close to 24 foot lbs.
