27 Roadster rear fender braces
Eric Sole
Topic author - Posts: 147
- First Name: Eric
- Last Name: Sole
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
My left rear fender has a bent iron brace (which also has an additional hole between the two standard ones).
The right rear fender has a stamped steel brace.
Were there different manufacturers or did they change the style at some point? Just wondering.
Re: 27 Roadster rear fender braces
Eric
Think the difference is the year, believe the solid bar type is early, had this solid type on my Nov. '25 Improved Car runabout pick-up. Guess the later pressed steel version saved some cost.
Cost/weight and perhaps cost of stock to make it. The late fenders were probably stiffer to to the changed contours, aslo.
Eric Sole
- First Name: Eric
- Last Name: Sole
Yah, the stamped piece has about 1/3 of the material of one solid one. Makes sense.
