At an auction today
Larry e rutt
Topic author - Posts: 154
- Last Name: Rutt
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordor
At an auction today
I'm at an auction today.. there is a box with demountable rims, coils,and these lens. Are they ford ?does anybody need them ? I could try and get them for you.. if not no worries
- Last Name: Humble
Re: At an auction today
Not Ford lenses, and probably will not fit a Ford electric headlight as most Ford headlight lenses have 4 flats to mount in the headlight rim retainers.
I believe the early rounds lens was for electric were 8-1/4" - 8-5/8" diameter. The H style came later. These lens usually have t he size in relief on the edge in the 5 o'clock position. They can be made to fit the H style and always look neat on a speedsterLarry e rutt wrote: ↑Tue May 03, 2022 7:30 amI'm at an auction today.. there is a box with demountable rims, coils,and these lens. Are they ford ?does anybody need them ? I could try and get them for you.. if not no worries
I'd be interested in the "bubble" lens' depending on size - are you able to get a measurement ?
Larry e rutt
- Last Name: Rutt
Sorry too late I left em go at 100... thanks
