Trying to find someone who can work on my 1919 engine and transmission. It has severe crankshaft end play, needs rebabbiting. Transmission also needs a look-at. I've been told piston rods may be bent as well. Valves are fine. There is also an explicably large hole cut in the timing gear case, plugged by someone quite a while ago.
Just need someone who can get the thing ready to put back in the frame, and hopefully fast.
Mechanic in Middle TN Area?
PaladinBirdy
Topic author - Posts: 23
- First Name: Josh
- Last Name: Hollingsworth
- * REQUIRED* Type and Year of Model Ts owned: 1919 Touring Pickup
A 'youngin.
