Do I need a bearing here?
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Post by Mustang1964s » Thu Jan 10, 2019 4:09 pm
I am rebuilding the steering column for the '27.
The column is in primer.
Is there a bearing that need to be in the bottom of the column?
Re: Do I need a bearing here?
Post by Allan » Thu Jan 10, 2019 4:36 pm
No!
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Jan 10, 2019 4:42 pm
No.
Post by DanTreace » Thu Jan 10, 2019 4:55 pm
There is a bushing to replace at the lower frame bracket for that steering shaft.
Once you drive out the old one, drive in the new.
Then ream that new bushing to size.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jan 10, 2019 7:59 pm
Nice work Dan!!!!!
Barth_Tool_Co
First Name: Jason
Last Name: Alvord
* REQUIRED* Type and Year of Model Ts owned: '26 Touring
Post by Barth_Tool_Co » Thu Jan 10, 2019 11:24 pm
Dan, what brand of adjustable reamer are you using there?
... and my number is Beechwood 4-5789
1926 Touring - "Corrina"
Post by DanTreace » Fri Jan 11, 2019 2:21 pm
Jason
Just a no-name brand from the local tool supply.
Any good 3/4" adjustable reamer should work. The reamer shown
is this 23/32" to 25/32" or 3/4" size. It was marked on the shaft "INDIA"
Dan
