Accessory Brakes with Double Drum- Any Info?
Speedsterguy2
Last Name: Knapp
* REQUIRED* Type and Year of Model Ts owned: 1919 Speedster (project)
Post by Speedsterguy2 » Thu Jun 02, 2022 4:32 pm
I was able to acquire these outside accessory brakes a few years ago, and finally got to taking them apart to see what they look like. The double drum is cast as a single piece, with the Ford size inside drum and the 10" outside drum. They seem to have little wear, but also appear to have been installed for long enough to accumulate mud, grease, and rust. There does not seem to be any identifying letters or name anywhere on them, but there is a "023" number cast into the mounting bracket / cross bar. I have not been able to find any period ads for anything that looks like these.
Does anyone know anything about them?
Thx / Tim
First Name: craig
Last Name: leach
Re: Accessory Brakes with Double Drum- Any Info?
Post by Craig Leach » Thu Jun 02, 2022 5:59 pm
Hi Tim,
don't have any idea who made them but looks like you hit the jackpot iron drums & self energizing in both directions. I have seen early Rocky Mountains like that but seems to Me they they had the name cast on them.
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Thu Jun 02, 2022 6:03 pm
You have the patterns. Start making them.
Post by speedytinc » Thu Jun 02, 2022 6:29 pm
Hi Tim,
AGREED. Those look like excellent brakes in design & function. I have not seen another set like these. I do like the medium sized drum.
I have a set that uses the outside of the original small drum. I can lock the brakes on my roadster forward or reverse.
Post by Wayne Sheldon » Thu Jun 02, 2022 8:14 pm
I don't recall what the mounting brackets were like, but the "Master Brake" used drums very similar to those. Some of the drums had the letters of the name spaced on the side of the drums to show between the spokes of the wheel. However, I have also seen them without the name on the drums.
Ed Archer I believe still has a set on Number 4.
Post by Original Smith » Fri Jun 03, 2022 9:30 am
Rocky Mountain riveted their large drum to the standard Ford drum. The diameter is considerably larger than posted above.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Jun 03, 2022 9:47 pm
The Master Brake drums were cast iron, but only had friction surface for the larger 10” (ish) drum. The original E-brake shoe and drum was abandoned
