Safety wire?
First Name: Keith
Last Name: Townsend
Safety wire?
Post by KWTownsend » Sun Jun 05, 2022 7:08 pm
Since these are drilled, are they supposed to be safety wired together?
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Safety wire?
Post by Jack Putnam, in Ohio » Sun Jun 05, 2022 7:18 pm
Yes. If wired they won't come out for sure.
OilyBill
First Name: William
Last Name: May
Re: Safety wire?
Post by OilyBill » Sun Jun 05, 2022 7:30 pm
Wiring them would be a good idea. They have the holes. Adding the safety wire certainly won't hurt anything. Check and see if someone in your club has a set of safety wire pliers. Most airplane mechanics have a set you could probably borrow for the 1 minute it takes to put safety wire in. I still have 2 sets of them in my toolbox from my work on airplanes.
Re: Safety wire?
Post by Allan » Sun Jun 05, 2022 8:13 pm
They just need to be stopped from winding out, so all you need is a wire between them to stop this. Maintaining tension with aircraft type twitching is overkill for this application.
Re: Safety wire?
Post by Norman Kling » Sun Jun 05, 2022 8:20 pm
It's good to have things wired in, especially things which could get into the crankcase and wreck you magneto or starter ring.
Re: Safety wire?
Post by speedytinc » Sun Jun 05, 2022 11:33 pm
Check your clearances with the bolt heads & clutch fingers. This area is real tight.
Re: Safety wire?
Post by Original Smith » Sun Jun 05, 2022 11:56 pm
I believe 1912 is the last year they did that.
Re: Safety wire?
Post by speedytinc » Sun Jun 05, 2022 11:58 pm
I had a 13 customer that had it also. Thats why I mention a caution about clearance checking.
