Generator testing out of car.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Sun Jun 05, 2022 2:13 pm
Any suggestions, shared knowledge, tips for testing a generator out of the car?
Re: Generator testing out of car.
Post by speedytinc » Sun Jun 05, 2022 2:44 pm
Gen test stand. See T1 manual. The gen needs to be made to run hooked up to an ammeter. Checking on your motor works. Does it produce voltage @ the terminal? The manual will give other tests by having it powered to motor with & without the 3rd brush down. A good battery or high amp battery charger for power.
Post by John kuehn » Sun Jun 05, 2022 2:57 pm
There is some good testing information in the MTFCA electrical manual. When working on a Model T the information is readily available about how to do it. The manuals are really helpful.
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sun Jun 05, 2022 8:07 pm
Connecting a battery to it and running it as a motor is a simple go/no go test, which will give some idea about the condition of the windings, brushes, and bearings. To test it properly, you really need to apply a rotational force at an appropriate speed, and feed it into battery or suitable load resistor in series with an ammeter. In other words, duplicate the in car set up.
Last Name: Hatch
Post by Dan Hatch » Sun Jun 05, 2022 9:35 pm
Here is what I use.
Post by John kuehn » Sun Jun 05, 2022 10:05 pm
Is your generator not charging or it’s not working correctly or?
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Mon Jun 06, 2022 5:23 am
Here is what I use .
Toon
Brent Mize
First Name: Brent
Last Name: Mize
* REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post by Brent Mize » Mon Jun 06, 2022 6:47 am
I use an Allen spin tester.
It does a great job and it’s compact.
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Post by Plankhill » Mon Jun 06, 2022 8:33 am
I made this one out of a generator bracket, an old timing gear, jack shaft, and old appliance motor.
Post by Scott_Conger » Mon Jun 06, 2022 1:46 pm
Brendan, in an age where we give prizes for just showing up, I think you deserve a STATUE for creativity. I love this on several different levels! :D
