I found it!
Several years ago Bob Cascisa and I were creating a complete and correct set of Model T wiring diagrams. I also prepared an article that addressed those pesky five charge/discharge wires that are commonly found incorrectly terminated resulting in incorrect charging/discharging Ammeter readings
A few people recently contacted me and asked for help and I had forgotten about this article.
Here it is:
Ron Patterson
Trouble Shooting the Model T Ford Charging System
Ron Patterson
- Attachments
- FINAL 11-18-18-Trouble Shooting the Model T Ford Charging System- .pdf
- (902.52 KiB) Downloaded 211 times
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Re: Trouble Shooting the Model T Ford Charging System
First thing I did this morning was print this, thank you Ron.
Ken
Ken
Work honestly
Stay true to your word
Get the job done right
Thank you Ron. This diagram is correct. However, when you are checking your car you also need follow each wire on your car to check both ends of each wire are at the correct terminal because, the existing wires on the car might not be color coded like the original. That is, the previous owner might have used different color wires than original.
John Codman
- Last Name: Codman
So did I.Ken Buhler wrote: ↑Tue Jun 14, 2022 10:01 amFirst thing I did this morning was print this, thank you Ron.
Ken
